Inventor Publisher
Talayoe
Message 1 of 9 (796 Views)
IPM Viewer Crashing
796 Views, 8 Replies
05-21-2013 07:57 PM
Hey all,
I have the ipm viewer on my ipad 4. I hit download, provide login creds and the. It crashes. Re start, hit download (now that creds are in) crashes.
I deleted, re-installed and repeated above and same thing.
Edit: just tried on ipad 2 and iphone 4, same. App broken??
Any ideas why his might be giving up?
-Randy
Inventor 2015 PDS
Employee
irene.chen
Message 2 of 9 (737 Views)
Re: IPM Viewer Crashing
05-30-2013 07:50 PM in reply to: Talayoe
I can't reproduce this issue at my side.  but I guess maybe it caused by the translator issue these days. Could you please try again according to steps below and let me know if it works now.
- Delete the app in Apple device.
- Download a new one from the App store instead of using update and install.
- Check if the viewer works.
Irene Chen
Talayoe
Message 3 of 9 (716 Views)
06-14-2013 10:13 AM in reply to: irene.chen
Hi Irene,
Sorry for not responding. I never saw the email notifier that this was responded too.
I gave this a whirl and the same issue happens. It is really quite frusterating. I should try again but on one of my other devices...Doesnt work on my iphone either (just tried).
This issue is quite annoying I have to say. Thanks for the response tho. :smileyhappy:
-Randy
Inventor 2015 PDS
Employee
irene.chen
Message 4 of 9 (659 Views)
07-16-2013 11:07 PM in reply to: Talayoe
After we did some research, below is what we found,
The application will scan the metadata XML downloaded from Autodesk Server after logged in. The crash was caused by trying to read the ‘Name’ attribute of the <Link> item  which does not exist in the metadata of some DWG files.
To fix your problem, Please try the workaround, you can group all the DWG files under the root into a folder on 360.autodesk.com and don’t touch it to avoid the crash after log in in Inventor Publisher Mobile Viewer.
Please let me know if it works after you try.
Irene
New Member
michael.rostad
Message 5 of 9 (520 Views)
08-28-2013 01:10 PM in reply to: irene.chen
I've tested reorganizing the root directory, and the app now allows me to login and see the directory structure.
Unfortunately, when I try going into the folder I created that contains a single Inventor .IPT format file, I experience the same crash out to desktop.
App info:
IPM Viewer
Version 1.6
App Size 19.2 MB
Please advise.
Member
Adam.Mounsey
Message 6 of 9 (469 Views)
09-06-2013 09:47 AM in reply to: irene.chen
I'm having the same issue, and the workaround doesnt seem to work.
Is there any solution for this yet?
Member
tylern
Message 7 of 9 (368 Views)
09-19-2013 01:24 PM in reply to: Adam.Mounsey
only *.IPM files can be opened in the viewer,
IPT files (inventor part) are not supported for viewing, they must be "Published" through the Inventor Publisher program.
Talayoe
Message 8 of 9 (364 Views)
09-19-2013 01:37 PM in reply to: tylern
Interesting change of pace here. I download iOS 7 for my iPad this morning (hate it!), but the Inventor Viewer for the first time ever since I have downloaded it, does not crash when I go to DOWNLOAD. It's a miracle! :smileyhappy:
Randy is happy now! <--- (me)
-Randy
Inventor 2015 PDS
Employee
irene.chen
Message 9 of 9 (348 Views)
09-21-2013 06:34 PM in reply to: Adam.Mounsey
Please update your inventor Publisher viewer with the new version released on September 18. This issue has been resolved.
Irene
Inventor Publisher QA
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
