Inventor Publisher
Valued Mentor
jweiss
Message 1 of 23 (1,902 Views)
Failed to Load File - Unknown Error
1902 Views, 22 Replies
04-12-2011 01:27 PM
I have 8 Publisher files that have apparently gotten corrupt after updating from Inventor.  We performed the update and the update was successful.  We made some minor changes and saved these files.  When we tried to open them the following day, we get an error that says "Failed to Open File - Unknown Error.  Please help!
Before and After datasets have been posted to Autodesk ftp site for evaluation.
John Weiss
CAD Administrator
Follett Corp
John C Weiss Jr.
CAD Administrator
Follett Corporation
Valued Mentor
jweiss
Message 2 of 23 (1,893 Views)
Re: Failed to Load File - Unknown Error
04-14-2011 05:09 AM in reply to: jweiss
Thanks to Jon and the Publisher team for fixing this problem for us.  All our Publisher files are working great again!
John Weiss
CAD Adminsitrator
Follett Corporation
John C Weiss Jr.
CAD Administrator
Follett Corporation
ahollingshead
Message 3 of 23 (1,870 Views)
04-27-2011 08:32 AM in reply to: jweiss
What was the fix for this issue?  I have run accross this on a few of my publisher files when I went from 2011 to 2012.
Employee
mccoym
Message 4 of 23 (1,865 Views)
04-27-2011 09:10 AM in reply to: ahollingshead
We are working directly with individual customers until we can get a public fix released, probably in about four weeks. If you need this fix right away, please contact me directly at manjiri.mccoy@autodesk.com.
Manjiri McCoy
Software Developer, Inventor Publisher
Active Contributor
VictorBDEngineer
Message 5 of 23 (1,718 Views)
07-19-2011 05:29 PM in reply to: mccoym
Has there been any further progress on this as I am having the same problem.
Regards
Victor Pringle
Employee
rajkumar.ilanchelian
Message 6 of 23 (1,703 Views)
07-20-2011 09:10 AM in reply to: VictorBDEngineer
Hi Victor,
We released a fix in our service pack 1 but later found that there are other workflow that exhibit  this issue. We are actively testing a fix at this time. I would like to get hold of the ipb file that is causing this issue for you. Also if you know of the workflow that caused this issue that would be good to know too. If you need a ftp location to send the files please email me rajkumar.ilanchelian@autodesk.com
-Raj (Autodesk)
Employee
Message 7 of 23 (1,683 Views)
07-26-2011 08:48 AM in reply to: rajkumar.ilanchelian
Thanks for sending the dataset Victor. I have repaired the file and send it back to you. As I mentioned earlier we are testing a fix for this issue.
-Raj (Autodesk)
Active Contributor
VictorBDEngineer
Message 8 of 23 (1,441 Views)
05-17-2012 07:06 PM in reply to: jweiss
I am still having problems with this issue on a new file. Has there been a fix?
The error occurs after making a small change to the Inventor Assembly files the .ipb is using. The Publisher file was saved before the changes were done in Inventor. The Publisher file now fails to load. A weeks worth of work is now down the drain.
I would have attached the files but they are too big to attach.
Regards
Victor Pringle
Employee
kumarra
Message 9 of 23 (1,431 Views)
05-18-2012 06:55 AM in reply to: VictorBDEngineer
Hello Victor,
Can you please tell me which version of Publisher you are using? Also do you have all the service packs installed?
I can send you a dropbox account to share the file. Will that be OK?
Rajkumar
Active Contributor
VictorBDEngineer
Message 10 of 23 (1,428 Views)
05-18-2012 12:31 PM in reply to: kumarra
I have Publisher 2012 SP2 (64bit) And Inventor Professional 2012 SP1(64bit) on 64bit Windows 7
Yes please for the Dropbox.
Regards
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
