Hi All,
Poor software design!
I have a suggestion for those who are busy on developing this software please ask the AutoCAD department for some help and direction because I think you don't know even the basics!!!!
HI Jahed,
It sounds like you're trying to use Publisher as you would AutoCAD (or Inventor, or any other CAD software for that matter). Inventor Publisher leverages the CAD data produced by those programs, but is NOT a CAD program itself, so it will not act exactly like one. With that said, the dimension tool in Publisher is a little different than you'd see in AutoCAD, etc. but is powerful in this specific environment. To address your concerns, please see below.
Timera Hart
Thanks for your reply.
Firstly, I am professional enough to understand and adjust my expectations when I am working with different software.
Why do you create boundaries around your business such as 'us' and 'them'? I faced to this issue many times when I open my mouth to criticize Inventor vs AutoCAD or Publisher vs AutoCAD or Inventor. Why don't you use the advantages of one software as a base for another?
It is obvious the logic of dimensioning in Publisher is not powerful for itself and in compare to the logic behind dimensioning in Inventor and AutoCAD. So instead of creating a funny logic just follow the case from other Autodesk software and don't raise your guard when somebody criticizes.
Unfortunately, sophism is not working on me.
Cheers
Ali
Publisher was created so that "Non-CAD" users could work on technical documentation freeing up engineers to spend their time designing.
Granted in a lot of companies, people have to wear many hats so pushing it off to a marketing person might not be an option, however it is easier for a CAD user to learn a "Non-CAD" program than the other way around.
I understand that. I don't want to create a model or draw something in Publisher. What I am saying is, this software has plenty unsolved problems regardless of who wants to work with it, a CAD user or a Non-CAD user.
For instance 'Dimensioning' or put a Text Box somewhere or use Leaders and etc are not related to what you are talking about.
