Do you have Service pack 1 installed? In Sp1 we fixed a save issue, but the downside was that it will not fix any existing ipbs with the issue. Also in the location of the ipb there is an old version folder that you can access to a working file.
If this problem is with Service pack 1, then I would like to take a look at the ipb. Please email me at rajkumar.ilanchelian@autodesk.com and I can send you a dropbox.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Hello Rajkumar,
I also had this problem. I have installed SP 1 (2013), but the problem is still occuring.
Tiziano
Hello Tiziano,
We addressed this issue in Sp1 based on the dataset that you provided. Are you havening this problem on a new file after you installed Sp1? Just a note that if an ipb already had this problem prior to Sp1 it cannot be unfortunately recovered with the fix we provided. The fix is to prevent this issue going forward. Please let me know if this issue was on the same file or a new file. If it is a new file I would like to have the ipb in the buzzsaw account.
Thanks in advance!
Autodesk Fusion
Join Fusion Insider
