Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Cannot Insert Assembly due to Custom Library
3 REPLIES 3
s.holland.cmc
599 Views, 3 Replies
Whenever I try to insert an assembly that contains parts from my own custom library (not located in the same file as the assembly) I recieve an import failure message stating that it can't find the part.  However, I can open that part from the library location just fine in publisher.  Is there a setting I can change, rather than having to copy all my parts into separate folders everytime I make an assembly?
3 REPLIES 3
Jon.Balgley
in reply to: s.holland.cmc
Are you using the "project file" option from the Insert dialog?  The "Options" button is only enabled once you pick the IAM file.
Jon Balgley
No, I didn't use that.  Thank you for pointing that out.  Is it possible to assign a project after you have inserted an assembly?
Jon.Balgley
Glad to help.  I know it's not obvious -- that's why I mentioned it.
The project file is ony used at import-time.  Once the assembly is in, it's in.
Jon Balgley
