Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
CMYK in Inventor Publisher
5 REPLIES 5
863 Views, 5 Replies
Greetings!
Erlier I posted a question how to adjust the color on you model using either RGB or CMYK.
I got an answer that worked with RBG values.
Now I'm in the same position only this time I can't use RGB because my document is supposed to be printed. Therefore I need the color values in CMYK. Is this even possible? How can I solve this problem?
I hoped that I could use the old .ipb document and change the colors from RGB to CMYK to save time.
Best regards,
Gisela Svensson
Technical communicator
5 REPLIES 5
Hi did you get any answer on this, I am needing the same in CMYK and also vector not pixel - print company wants everything drawn in illustrator, that totaly kills the value of modeling in Inventor, am presuming there must be a way to convert automatically.  Thanks in advance.
I did not get the answer for this problem. I understood after some time that Publisher is not a good tool to use for printed illustrations. Even though you can publish the snapshots as vector and work with it in illustrator I find it much better to convert the CAD-data to a .stp-file and then work with it in ISOdraw and illustrator. This method is a bit more expensive but when I could show my customer the difference in quality there were no more discussion.
As for CMYK, I didn't find out how to solve that so I manually changed the colors in illustrator when I made the final touch-ups on my illustrations.
I still work with Publisher sometimes but I believe that Publisher is the forgotten child of Autodesk 😞
Kind regards,
Gisela Svensson
Technical Communicator
Huan.Yu_Autodesk
At this point, Inventor Publisher only supports RGB.
Inventor supports both RGB and HSL.
Does HSL work for you?
-Huan
in reply to: Huan.Yu_Autodesk
Hi Huan,
Thanks a bunch for the response
Unfortunately it does not, their expectation is very limited cmyk with vectors not rgb with pixels. We found a crude expensive solution via pro engineer export 😞
Hoping very much for a native solution in inventor one day 😉
Huan.Yu_Autodesk
Thanks for the additional info.
Your requirement is well noted.
-Huan
