Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Appearance Style
5 REPLIES 5
rich-s
1284 Views, 5 Replies
Appearance Style
Ok so I've made a custom appearance style, but how do I save it so I can reuse it vs. having to recreate it every time I start a new publication?
5 REPLIES 5
TimeraAutodesk
in reply to: rich-s
Hi Rich -
Currently, there is no way to copy custom appearance styles between projects. The custom styles that you've created are only available within the project they were created in - this is currently as-designed.
Timera Hart
rich-s
in reply to: TimeraAutodesk
I was talking with my reseller and they suggested the following;
1. create a project with all my customizing
2. save as "template.ipb"
3. to start a new project, open "template.ipb" and save as "new_project.ipb"
4. erase all components
5. insert compoents
thoughts?
TimeraAutodesk
in reply to: rich-s
This is a viable workaround, although you dont need to insert any components/data to set up and save an IPB file. I'd suggest just to cancel out of the Insert dialog that pops up when you create a new project, and then set up the styles as you need. This way you don't run the risk of possibly mixing datasets or anything in the future.
Timera
bowen192
in reply to: rich-s
I too think this would be a great feature for a future update.
JBerns
in reply to: bowen192
Autodesk Team,
  • When will it be possible to copy Labels, Callouts, and Arrows between publications?
  • When will it be possible to export/import Styles (Appearance, Label, etc.)?
  • When will Zoom All (Extents) respect the Publish area instead of the application window?
Jerry
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
