Ok so I've made a custom appearance style, but how do I save it so I can reuse it vs. having to recreate it every time I start a new publication?
Solved by TimeraAutodesk. Go to Solution.
Hi Rich -
Currently, there is no way to copy custom appearance styles between projects. The custom styles that you've created are only available within the project they were created in - this is currently as-designed.
Timera Hart
I was talking with my reseller and they suggested the following;
1. create a project with all my customizing
2. save as "template.ipb"
3. to start a new project, open "template.ipb" and save as "new_project.ipb"
4. erase all components
5. insert compoents
thoughts?
This is a viable workaround, although you dont need to insert any components/data to set up and save an IPB file. I'd suggest just to cancel out of the Insert dialog that pops up when you create a new project, and then set up the styles as you need. This way you don't run the risk of possibly mixing datasets or anything in the future.
Timera
Autodesk Team,
Jerry
