• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Mesh Enabler
    Active Member
    manufacturing STL files
    416 Views, 7 Replies
    12-18-2011 03:43 AM
    This option have very good potential in manufacturing
    I would like our team to test it - and if ok to ask real users to check it as a manufacturing option
     the problem is that we use STL files as input
     can you please recomend/provide me with a translator from STL to CATIA Mesh (which is used by this option) - so we can test it ?
    I think many of our 6000 users will use it because it enable working on parts in stages:
    you perform manufacturing operations then get simulation result in STL
    and continue to work on the result
    in 3D parts it happen several times.
    Also there is the area of interest of reverse engeneering (scanning 3D ...)
    it will be nice to understand why you don't import STL. I guess converting from one mesh file format to another is almost terivial. So maybe there other reasons (CATIA mesh have special properties?)
    If it is only a technical Mesh conversion issue and you can't find a convertor STL --> CATIA Mesh
    maube you can provide me the binary file format of CATIA mesh you are using so I will do the convert myself?
    thanks, Eran
    Please use plain text.
    Board Manager
    Re: manufacturing STL files
    12-20-2011 04:30 PM in reply to: eran
    Thank you for the suggestion. For a future release, we can consider adding support for importing STL files directly into Inventor.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Employee
    12-20-2011 04:35 PM in reply to: eran
    Hello, Eran.
    Have you tried the enhanced mesh import capability in Inventor Goodyear Beta?
    If you want access to the Beta, please get in touch with Chris Mitchell (chris.mitchell@autodesk.com).
    --John
    Active Member
    12-22-2011 03:42 AM in reply to: jncallen
    Hello John
    I'll check it
    Thanks, Eran
    Active Member
    12-26-2011 01:58 AM in reply to: eran
    From a brief view Inventor 2013 can import  STL and point cloud
    Question is what can be done with it:
    API - what data can be obtained from these Mesh objects
    user - pick, measure
    It is just asked for that a kind of  "Mesh Enabler" will provide a solution to promote  the imported STL Mesh and point-cloud objects to B-Rep surfeces / solids. This will be fantastic for manufacturing !!
    Board Manager
    01-13-2012 10:59 AM in reply to: eran
    Under the beta agreement that you signed, betas are discussed in the beta forums and not in these public forums.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Active Member
    01-15-2012 01:30 AM in reply to: scott.sheppard
    Hello Scott
    I thank you for leting me know that you find my post problematic.
    In any case you find a post of mine offending Autodesk interests in any way, please remove it immidiatly
    and email me.
    I was told to check the Beta so I did and reported my foundings.
    I would thank you if you could give me a link to the propper forum where this subject should be discussed
    thanks, Eran
    Board Manager
    01-17-2012 06:58 AM in reply to: eran
    Actually my reply was to you and jncallen. Once a post has been posted, it is really out there. They can be deleted, but with RSS feeds, the cat is out of the bag. I never delete anything from the internet. The beta.autodesk.com site has forums dedicated to our betas.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
