• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    19 Kudos
    set precision for measure command
    Status: Accepted
    by Contributor alundr on ‎12-19-2012 06:12 AM
    Set the precision for the measure tool in the application options.  I am always extending this out.  It currently has to be set each day at each document level.  I just want to set it once, not reset it 50 time a day.
    Status: Accepted
    Accepted Idea [US13626]. Thanks!
    Comments
    by Contributor Pacetech on ‎01-02-2013 02:11 PM
    Also, the ability to set all measurements to DUAL UNIT in inches and mm.
    by Employee steven.dennis on ‎01-29-2013 01:08 PM
    This is on our radar. [US13626]
    by Active Contributor jberns on ‎02-06-2013 02:36 PM
    The precision should apply to all fields in the Measure box.
    In the example below, the precision (8 decimals) is not applied to the Position or Delta values.
    Lack of precision can cause round-off errors. When incorrect values are used in Tube & Pipe runs, overcomplicated routes result because an aligment may be off in the 4th or greater decimal place.
    Projecting or including geometry does not always resolve the issue for the pipe route.
    by Distinguished Contributor CADDapult on ‎02-07-2013 07:30 AM
    While routing pipe a misalignment of 0.0000001 can turn what you think is going to be a straight-line pipe run into a pretzel.  Then try and find where the problem is, when you can't set the Position and Delta unit precisions fine enough.  If the piping requires umpteen decimal place precision while routing, Inventor needs to have an option to show that same precision when checking X/Y/Z locations and deltas.
    Mike
    by Employee dan.szymanski on ‎03-18-2013 08:50 AM
    Status changed to: Accepted
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea.
