33 Kudos
set precision for measure command
Status: Accepted
by Active Contributor alundr on ‎12-19-2012 06:12 AM
Set the precision for the measure tool in the application options.  I am always extending this out.  It currently has to be set each day at each document level.  I just want to set it once, not reset it 50 time a day.
Status: Accepted
Accepted Idea [US13626]. Thanks!
Comments
by Contributor Pacetech on ‎01-02-2013 02:11 PM
Also, the ability to set all measurements to DUAL UNIT in inches and mm.
by Employee steven.dennis on ‎01-29-2013 01:08 PM
This is on our radar. [US13626]
by Valued Contributor jberns on ‎02-06-2013 02:36 PM
The precision should apply to all fields in the Measure box.
In the example below, the precision (8 decimals) is not applied to the Position or Delta values.
Lack of precision can cause round-off errors. When incorrect values are used in Tube & Pipe runs, overcomplicated routes result because an aligment may be off in the 4th or greater decimal place.
Projecting or including geometry does not always resolve the issue for the pipe route.
by Distinguished Contributor CADDapult on ‎02-07-2013 07:30 AM
While routing pipe a misalignment of 0.0000001 can turn what you think is going to be a straight-line pipe run into a pretzel.  Then try and find where the problem is, when you can't set the Position and Delta unit precisions fine enough.  If the piping requires umpteen decimal place precision while routing, Inventor needs to have an option to show that same precision when checking X/Y/Z locations and deltas.
Mike
by Employee dan.szymanski on ‎03-18-2013 08:50 AM
Status changed to: Accepted
You are not logged in.
IdeaStation Guidelines
Review guidelines and best practices
before posting a new idea.
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
