revision block dates
on the revision block, when add new ow is selected, can the date default to the current date,  it seems to default to the date the revision block was inserted, and if the revision block is in the template, it defaults to the date the block was inserted into the template
5 Comments
LT.Rusty
Just out of curiosity, why would you want the date for the revision block to default to something other than when it was inserted?  If you have it automatically set to whatever the current day is, then you'll be changing the date on it every time you open up the drawing.  That doesn't make much sense.
The revision date comes from iProperties: Eng. Approved Date.
dvsmiller9
Can we have a setting in Application or Document options to pick which iProperty the Revision block grabs the Approved by and Date from?  Not every company uses the Engineering signoff as the Rev block authority. This option should let you configure to use either one of the standard Status tab iprops or a custom iprop signoff and date.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
