Inventor Forum
offset on rectangle
7 REPLIES 7
Message 1 of 8
LeanderTorres
1003 Views, 7 Replies
offset on rectangle
Hi there,
When drawing a rectangle with the midpoint command inventor palces the diagonals.
If you trie to offset the rectangle it won't recognice the figure as a loop, you need to delete the construction lines for creating an offset of the complete rectangle in one go. (= time consuming)
Isn't it possible to let inventor detect loops only within 1 linetype, or make an option out of it?
Kind Regards,
Leander Torres Falcato Simoes
Hego bvba
Labels (3)
7 REPLIES 7
Message 2 of 8
mikeh4
in reply to: LeanderTorres
You beat me to it.  Centerpoint rectangle is fabulous, but if we can't offset it, there's no time savings in using it.
Message 3 of 8
fsanchou
It's possible in version 2015
Message 4 of 8
Why did you use offset? Why not using center point rectangle a second time??
Message 5 of 8
@michael
cause the spacing wouldnt be the same all around, I would have to place 2 dimensions vs 1 with an offset-command.
Message 6 of 8
Its solved in 2015
Message 7 of 8
Dan Szymanski
Product Manager
Autodesk, Inc.
Message 8 of 8
lesmfunk
in reply to: dan_szymanski
Spending more money is not a solution for something that should have worked in the first place. One place I work at still uses 2014, and there appears to be no fix for it.
UPSELLING IS NOT A SOLUTION
Shame on Autodesk.
