Show only
Search instead for
i can use 3d sketch for loft command solid body modelling.But i can not use 3d sketch for sheet metal lofted-flange command.We can use 3d sketch for sheet-metal lofted flange command.
We really need to be able to select a 3D sketch when creating a Lofted Flange. When we have a large press brake plate forming a pipe that intersects a large tank, we need to be able to select the 3D sketch as a profile in the Lofted Flange dialog box. It would make creating these pipes, or any type of transitions, easier and quicker to model.
Hence my idea of being abe to flatten non developable surfaces. There is no point is being able to create a complex sheet metal loft if you cant flatten it.
I agree with this idea. Here is a sample from the industry. One of our customer who designs fluid tanks asked me how they can create this transition geometry using sheet metal and then generate flat pattern. I couldnt create the exact geometry only one approximate model.
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found
that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
