we probably all see at times it could be good to hit a key instead of clicking on an okay or accept or cancel button, especially if we wish to continue further (need to click ok or accept many times) and the default focus happens to be on the cancel key!
i have attached a snapshot of such a case.
not to divert away from the idea but this default focus should be on the "Accept" key (having to reattach quite a few dimensions that have broken away from the geometry)...
so, in the case of re-attaching dimensions or leaders or other attached annotations, there is an intensive need to click almost every time something is reattached if there is still a portion of the annotation that still needs to be attached (eg the dim extension line down the other end of ths shaft in this case).
if i could just keep hitting the "A" key (non mouse hand) while reattaching annotations (with mouse clicks) i could be cutting down the clicks and time to get the drawing sorted, and hopefully get another job out the door quick enough so i can catch the pie van at smoko...
