create iparts with multiple tables
It would save lots of time and effort if you could create iparts with multiple tables.  For example, if you had one table with dimensions for a bolt head, and a second table with thread information, you could build an entire matrix of parts with a single ipart.  You could make round head, cheese head, pan head, and truss bolts.
3 Comments
cadull_rb
I can see the benefit in this where a number of options are independent (i.e. any combination is valid). A boolean expression to control which combinations are allowed would make this more flexible.
This should also be applied to iAssemblies.
There would need to be a combining table where values could use expressions to combine data from each table. Similar to expressions in content center, this would help in setting the member name and file name. It would also assist in controlling which member to use for included iPart/iAssembly occurrences.
cadull
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
