change representation in ipn files
I would like the ability to change the representations used in an ipn file after the view has been created. Currently we can choose the view, position, level of detail and associativity when a new explosion is created, but we cannot change this after the explosion has been created.
I cannot see a workaround for this, other than to create a new explosion. Changing the representation used could save so much time.
I appreciate that some tweaks may be broken by changing the representation, but for the most part I would see this as saving a lot of effort.
Kenny
6 Comments
tkanusky
The presentation environment is in dire need of improvement.
BrotherkennyhDWR
Thanks for pointing out the previous threads. I don't know if Autodesk ever plan on working on this, but its about time they put some work into it. As far as I am concerned they should be making imporvements with every release. Presently I can't remember when the presentation environment last changed.
dan_szymanski
Status changed to: Duplicate
Hello Kenny,
This Idea is a duplicate of the following enhancement request:
http://forums.autodesk.com/t5/inventor-ideastation/fix-the-ipn-s-associativity-issues/idi-p/4750673
Please cast your kudo to the Master Idea as to not split votes.  Thanks! -Dan
dan_szymanski
This Duplicate idea has been implemented within Autodesk Inventor 2016. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it.
kpalumbo
We gotta be able to change a positional rep in an IPN, if I want.
Regardless, if its going to mess up the existing tweaks, that should be my call.
TU
