Show only
Search instead for
Why can't we export text parameters to iProperties for easy use in title blocks? This is so simple and useful, I can't believe it isn't already posted.
Akosi, this is how I do it right now. If you have more than one parameter, change the identifer in the code. I use this all the time for Titleblock automation where a Custom Parameter is needed from a MultiValue Text Parameter in the Parameters box.
It would be much easier to have these parameters directly accessible instead of having to resort to code to get the same info as a numerical parameter.
Would be nice if you could link them between using the derived part/assembly capabilities as well. For a final step I'd like to see them usable on the conditional suppression on a feature. It can be done via iLogic, but a simple true/false that can conditionally suppress a feature and be shared would be very useful.
