Export Text Parameter
Why can't we export text parameters to iProperties for easy use in title blocks? This is so simple and useful, I can't believe it isn't already posted.
31 Comments
BLHDrafting
Likewise, I want to use text parameters to drive an emboss feature for an iPart that I then want to publish to the Content Centre.
akosi
Why cant we export text user parameter ???
we can for numerical type...what is the issue for text type!!
it would help us tremendously ,
by exporting text parameter, we can write whatever and be able to derive it for other parts.
please please....make this happen..
Tags (3)
mrattray
mflayler2
You can do this now with iLogic code, but I agree that it should have standard user availability.
akosi
To mark ...
would you be able to share on how to do that in ilogic.? pleaseeee..
i can settle for that in the meantime...
mflayler2
Akosi, this is how I do it right now.  If you have more than one parameter, change the identifer in the code.  I use this all the time for Titleblock automation where a Custom Parameter is needed from a MultiValue Text Parameter in the Parameters box.
http://blogs.rand.com/manufacturing/2012/09/inventor-ilogic-multi-value-text-parameter-to-custom-ipr...
akosi
I dont want my text parameter to go to custom properties. Id like to derive the text parameter with the solid.
is there anyway i can attached any text (ex. description) to a derived solid?
Bill.Bogan
I'm all for this if you include exposing User Parameters in iPart tables for use!
If I have different product model sizes with unique part numbers, I'd like the embossed part number to match the selected product model.
- User parameter, text type, multi-value
- iPart, use parameter in column
   - in the table, the cells in the column would each have a combo list of the text parameter values.
DesignProduction
I would like to be able export and import text parameters into other parts especially derived parts.
DRoam
Please allow the ability to export text parameters for use in other components.
nicolaslegare
=The parameters cant be add in iproperties for the virtual parts
=The text parameters can't be export as numeric parameters.
mflayler2
mrattray
I assume you mean something along the lines of:
iProperties.Value("Custom", "Your Parameter Name Here")
andrus.randveer
Any hope to get this implemented? It would enable quite a lot of automation possibilities.
2018 tick tick tick tick....
mgrenier25
Please make these parameter exportable so it is possible to re-use them in a drawing.
philip1009
It would be much easier to have these parameters directly accessible instead of having to resort to code to get the same info as a numerical parameter.
wgraham
Would be nice if you could link them between using the derived part/assembly capabilities as well.  For a final step I'd like to see them usable on the conditional suppression on a feature.  It can be done via iLogic, but  a simple true/false that can conditionally suppress a feature and be shared would be very useful.
wgraham
