Smarter Diameter Dimensions
Shouldn't Inventor know that this is a cylinder and should therefore have a diameter symbol? Let's have it pop in there on its own without me having to do an edit text operation on it and manually add it.
71 Comments
Cadmanto
Mike,
When you insert the dimensions directly from the model into the drawing the Ø comes with the dimension.
But I know what you are saying.  Make the dimension tool more intuitive.
mrattray
Scott,
I model for easy editing and configurability. I don't want to have to change my modeling practices to suit drafting requirements, which is what I would have to do in order for my sketch dimensions to be placed in an appropriate place for my drawing using the retrieve dimension command (that is what you meant, right?).
Curtis_Waguespack
Hi  mrattray,
If you click the vertical line rather than the the two horizontal lines or two points you should get a diameter symbol as you expect. Is there an improvement to this that you are recommending?
I hope this helps.
Curtis
mrattray
Curts,
I actually didn't realize that.
I've been in the habit of dimensioning between two edges whenever possible for many years across multiple CAD packages to avoid orphaned annotations after making changes.
It's a pretty minor thing, but I'm suggesting that Inventor extends this functionality to a dimension created between two lines. -OR- Maybe, Inventor can be a little smarter about orphaned annotations so I don't have to dimension between two lines in the first place?
Curtis_Waguespack
Seems reasonable enough that it could work that way, I'll give it a vote.
mrattray
I couldn't come up with an example of where I don't even have a line to grab a diameter at until I finally came across one while detailing real parts. The .984 dimension in the image should have a diameter symbol, but I don't have a vertical edge to select.
CelticDesignServices
This would be an example of how my request here for In-Stream modifiers for Dimensions can be of great help.
You'd simply have the option to select the diameter symbol as active, prior to inserting the dimension.
I would vote for that CDS.
dan_szymanski
Note: If you're dimensioning up a sectioned shaft, there are no real vertical lines for the OD at all, so the vertical option isn't even available then.
Would it be possible to make a general "project broken corner intersections" option to simplifiy this?
Normally, the chamfer on the end is just there to break the corner or add a weld groove, as a result the chamfer is small.  Would it be possible to have a button that adds a clickable point at the intersection of any two large lines that meet with a small third taper?
mrattray
Kevin, I'm not sure how that would be different from picking the lines. Can you elaborate?
livewire77
Inventor should recognize this as diameter and automatically place diameter symbol before text. Solidworks can do it.
Tags (2)
jletcher
So does Inventor..
Rory_M
Unfortunately it doesn't, at least, not automatically.
If the edge of the right hand view was a single unbroken line then yes it could be done, but the example shown requires the user to pick the two parallel lines and this results in a linear dim with no Ø symbol. You could do it if you brought the dimension through from the model though but that's not always practical.
Hm, I was thinking if it projected the corners, it could flag them as a single line/cross piece.  Unless you're putting the program on a CNC, the borken corners aren't important to the overall design, it would just take three points (two ends and a center) and view it as a single point to grab.  Visual simplification.
timdown73
Agreed, If you are dragging a dimension from the edge line of a curved surface Inventor should at least give you the option of adding the symbol on the fly.
You can also do it manually to some degree.
1) Create a centerline between the two edges.
2) Dimension one edge to the center line: (two click operation)
3) Right click and select "linear diameter" under dimension type:
4) Set center line to invisible.
It's an exceedlingly tedious way to do it if you've got numerous diameters though.
timdown73
Smiley HappyAgreed, not intuitive but good to know.
I went ahead and made a suggestion here.
