Slot annotation
Slot annotation
I use a lot of rounded mortises in creating woodwork items which are essentially slots cut into the wood. I'm not sure if there is a standard notation for slots but it would be good if there was a command similar to the Hole command which could automatically annotate slots (eg. Slot Width x Slot Diameter x Slot Depth maybe). Maybe even a Centre Mark command which could recognise the slots as a complete entity and automatically insert two perpendicular centrelines would definitely be handy.
6 Comments
mikeh7
We use a lot of slots in sheet metal.  Our dimensions are to the center point of the slot as we punch our slots.  So we need overall height and width of the slot and the center point.  Depth isn't an issue to us a it's always through.
Would be big for us.
Thanks!
Josh_Hunt
This is a great idea, however Autodesk needs to create a "Slot Feature" before they can have Automatic Slot annotation. A Slot sketch command has been implemented in 2014 but that doesn't give you the full details you need.
Give Kudos to this first. http://forums.autodesk.com/t5/Inventor-IdeaStation/Slot-Creation-in-modeling-mode/idi-p/4601899
ben.powell
THIS IS A MUST!
We use slotted holes a lot.
An actual seperate slot feature (similar to the existing hole feature) is needed.
Not only for annotating easier in the drawings but also so that it creates a central axis and you don't then have to create your own to constrain bolts etc. to.
Exactly. Even if it can recognise the feature from the slot sketch would be
great too. I mentioned it years ago, but it's just another useful "feature"
that Autodesk ignore.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
