Show only
Search instead for
Hello, could you please provide some additional requirements surrounding this request? Are you asking for a flange or fold that is curved and does not possess a bend line? Do you have any images you can share with us in better understanding your idea? Thanks in advance. -Dan
In SolidEdge, would you (or anyone) happen to know if you are able to flatten the curved flange (displayed in your top image)? Also, can anyone share how the top part might get manufactured in the real world (perhaps weld and grind?). Thanks again! -Dan
If I were to manufacture the top part, I would bend up the two straight flanges on the first part and make a second part that is roll-formed or step-bent to make the S-shape. Then fit, weld, and grind if necessary.
That's given that the part is relatively large and the metal is thick. There are some times that flange we're forming along a radius is only about 0.250" tall and the material is 20ga. or less. In that instance, we use a turning machine that has two wheels, one a vee in and the other a vee out (like a punch and die on a press brake). As you roll the edge through the machine, it turns a flange at about 90°. This obviously deforms the metal, so thicker material and longer flanges tend to warp.
I posting below my article/forum as "Idea" because not found any easy solution from Forums or from other source
I think with picture you will understand what are my requirements. In Image-1 you can see a plain disc with a vent hole and I want to add flange with circular corner at yellow marked edge (Image-2) as we can do with flange command. But problem with flange command is that I can not select circular edge to add flange on this edge
One solution which I know is draw the profile and revolve it in 3D model (.prt file) but I do not think it is a correct way to add the flange (add two partsor volumes) also we can not add corners and other stuff with one command like we can do in flange or contour flange command. With flange command we can not select circular edges but can select straight edges.
So my Idea is "allow selecting circular edges for Flange command in Inventor Sheet Metal"
I don't see how you could actually bend something like you are showing. This is something you could print with a 3d printer or perhaps mold inject but you could not fabricate it with a press out of metal.
Thank you to all for considering my Idea and giving time to it.
@CCarreiras here I not considered the process which we need to follow but at the same time I am seen some part which are from Steel sheet metal but I don't which process manufacturer has followed to make it. coming to my point please see the below picture and comments
Below first two picture shows what is my design requirements
below pictures show process which I followed to design it. (Pictures are self explaining)
So below are my comments/reasons to upload in this as Idea
I do not think above process is correct way to add the flange because there are lots of trial and errors we have to do, like for revolving flange at what angle? addition of two volumes which will not give correct weight!! also we can not add corners defaults but done manually. Process is time consuming
If we see flange command in sheet metal we can add flange in one stroke and do not need to folllow above over designing but problem is that we can not select circular edges but can select only straight edges.
Hence and So my Idea is "allow to select circular edges for flange command in Inventor Sheet Metal"
I hope i described it correctly to understand everyone.
