Sheet metal Multibody!!!
Now, I think it is indispensable the Mudibody model in the sheet metal environment.
And you, what do you think about this?
4 Comments
MrJoshuaAU
As I posted before, this is a must and Inventor is so far behind the competition in this area. Most of what we make is near impossible with the current sheet metal environment. Being unable to put a simple mitre between 2 separate sheet metal parts is a major PITA. Multi body sheet metal is a MUST...
dan_szymanski
Hello everyone,
The idea for MSB (multi-solid body) support in SM has been posted under the following link on the idea station.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Solid-Body-Sheet-Metal-Parts/idi-p/3700228
As such I am modifying this as a DUPLICATE so that we do not split up the Kudos between the same idea.
Thanks & regards,
Dan Szymanski
dan_szymanski
Status changed to: Duplicate
dan_szymanski
The Master Idea of this duplicate has been implemented within Autodesk Inventor 2016. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it.
