- Mark as Read
- Email to a Friend
- Printer Friendly Page
Sheet Set Manager for Inventor Drawings
Status: New IdeaThere is a need for many fabrication type design departments to create sheet sets for their drawings. Currently Inventor's multisheet drawings have a number of shortcomings for doing this. Something like AutoCAD's Sheet manager tool in Inventor would help with many of the issues. See this link:
http://inventortrenches.blogspot.com/2011/05/using
- Mark as Read
- Highlight
- Email to a Friend
The only drawback I see to sheet sets, is that in Vault, you have to print the dwf of each sheet one at a time. With the Inventor multi sheet drawings, one click prints the dwf of all sheets. I know Vault has a batch plot function, but that won't work on the Item Master dwf with the Watermark. Put a batch plot function down on that window, and now we're cooking with gas.
- Mark as Read
- Highlight
- Email to a Friend
I'd love a sheet set feature as well.
At least in Autocad, if you have 6 layouts on a single dwg file, they are listed in the sheet set as separate sheets and you can easily print any one or combination of them. You are not restricted to printing all the sheets in a dwg.
We're using dwgs with inventor here and the sheets work just fine in autocad sheet sets, but you can't access all the sheet set parameters through Inventor, you've got to load the file up in autocad.
The only real issues this causes are having to use autocad for sheet set work.
Sure, I can use the Task Scheduler to print multiple sheets/files, but you wind up setting it up and adding whatever sheets you want/need every time. One of the things I love about sheet sets is being able to select any number/combination of sheets and shoot them to any printer i choose with maybe 2-3 clicks. No opening the files, no opening another program, no opening another dialog, just hover over the sheet set bar and boom, a couple clicks and the sheets are printing.
Something else that sheets sets would bring would be parameters that can be shared throughout a project. I can put job and customer info in my titleblocks using the sheet set. Then, I make a change in the sheet set paramters and instantly reflected on however many drawing sheets I have in the project in question whether it's 3 or 3000 sheets. There doesn't seem to be any real method of doing that in inventor right now.
