Select Other - drop down needs moving out of the way please
most of the time the little "Select Other" visual feedback is being blocked by the nice (but often very annoying) little selection box.
lots of people complain and yet we still have it doing the same thing, getting in the way.
can you fix this please? ie move it away a bit, or if user moves it away from geometry attempting to be chosen, then make it stick to where the user manually positions it...
19 Comments
dan_szymanski
Status changed to: Accepted
Accepted idea [US-53056]. Thanks!
DRoam
See this thread suggesting an alternate solution to this issue:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Select-other-with-keyboard-button/idi-p/3821633
QuasiMojo
It would be very nice if the pop-up menus, particularly the selection menu that appears on hover, did not obscure the very item we are attempting to select.  For instance, when attempting to select a vertex, I place the cursor over the geometry and wait for the selection menu to block it from my sight. Then I have to move it and select.  The fact that there is no way to distiguish which "vertex" is the vertex I want when several are listed is a subject of a different thread I think.DialogHell.gif
QuasiMojo
I just found this topic was already covered here  and marked accepted.  Sorry for the redundant post. Send kudos over there instead...
Cadmanto
QuasiMojo
Yes, it's a similar problem but the mini-toolbar can at least be pinned to a specific location so it doesn't get right under the cursor.  That's about the only thing the mini-toolbar has going for it...it should just be trashed in my opinion.  I think this obscuration problem is more akin to the shotgun appearance of viewing constraints rather than the shoddy implementation of the m-t.
<rant>All in all, it leaves me with the conviction that Autodesk does not USE their own software; rather, they focus on adding half-baked features that look good in marketing print and shareholder reports.  I suspect the investors matter more than the professionals who pay for subscriptions.  </rant>
Mark_Wigan
i aggree Quasi. we have been asking for this to be sorted for a while...
Josh_Hunt
QuasiMojo, excellent animation to show the issue. Check out this same idea with 70 votes.
http://forums.autodesk.com/t5/Inventor-IdeaStation/Select-Other-drop-down-needs-moving-out-of-the-wa...
QuasiMojo
Hi Jhunt107,
Yes, you're right; once I found the post you referenced I tried to direct people over there with the link in my first comment.  It seems no one noticed Smiley Happy
The animated gif was created using an oddly-named but very useful program called LICEcap
Cheers
timdown73
Please implement this idea soon!  This is unacceptable as is and VERY FRUSTRATING.  I don't know how this made it into Inventor without being tested but apparently it wasn't because if it were, this BUG would have been fixed before the selection tool update.
dan_szymanski
Status changed to: Gathering Support
Hello QuasiMojo, it is amazing what an incredible animated gif can do for an Idea.  🙂
As noted below, this Idea is a duplicate of the following post:
http://forums.autodesk.com/t5/inventor-ideastation/select-other-drop-down-needs-moving-out-of-the-wa...
Please be sure to cast your kudo to the Master Idea as to not split the votes.  Thanks! -Dan
QuasiMojo
I did. Long ago.
DRoam
See this thread for yet another solution to this issue:
Better Select Other Functionality
Unlike the one I posted above, this one specifically requests doing away with the annoying drop-down box altogether and simply toggling the selection using a keyboard or mouse shortcut.
dan_szymanski
This idea has been implemented within Autodesk Inventor 2017. Special thanks to everyone who cast a vote for it.
robmatthews
Can the fix be rolled back into an SP for 2016 please?
DRoam
Hi @dan_szymanski, what change was made to this in 2017? I'm using Inventor 2020.3 and when I use Select Other in an assembly or a part, the box pops up directly under my cursor, obstructing what I'm trying to select:
Is this a regression from 2017? Or do I need to change a setting somewhere?
JoyceZhou
Hi DRoam,
Could you please help add one video for your workflow and also attach one dataset for the issue?
I could not reproduce it on 2020.3 and the later 2021 build.
Joyce
JarFu
@DRoam, the default time is 2 sec for "Select Other" delay (under Application Options> General), when mouse hover lasts 2 seconds, Select Other box will popup automatically. Please double check if need change this value to bigger.
DRoam
Hi Joyce and Jar, thank you for responding. I think I see what the issue is now. Jar mentioned the Select Other delay -- I have this turned up to the maximum (20 seconds) because I don't ever want it to pop up automatically, only when I ask it to via the keyboard shortcut. And it's when using the keyboard shortcut that it pops up directly under the cursor and gets in the way. If I wait for it to show up after the delay, the cursor and Select Other box do indeed correctly jump out of the way a bit.
Please try using the keyboard shortcut to bring up Select Other, rather than waiting for the delay, and see if you can reproduce the issue that way. Thank you!
