Idea Options
- Mark as Read
- Email to a Friend
- Printer Friendly Page
11
Kudos
Add an option in parts created from derived components to replace the derived component.
Status:
Curtis' solution works but we already are considering building it in. [US4564 ]
Another workaroudn solution is to rename the file you derived FROM and open the derived part. When you get the resolve file dialog pick the one you want to replace the original source with.
Comments
Options
- Mark as Read
- Highlight
- Email to a Friend
This is a good suggestion, I do this now with an iLogic rule, but it would be nice to have it built in.
Dim oDoc as Document oDoc = ThisDoc.Document Dim oRefFile As FileDescriptor Dim oOrigRefName As Object For Each oRefFile In oDoc.file.ReferencedFileDescriptors 'get the full file path to the original internal references oOrigRefName = oRefFile.FullFileName 'present a File Selection dialog Dim oFileDlg As inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg) oFileDlg.InitialDirectory = oOrigRefName oFileDlg.CancelError = True On Error Resume Next oFileDlg.ShowOpen() If Err.Number <> 0 Then Return ElseIf oFileDlg.FileName <> "" Then selectedfile = oFileDlg.FileName End if ‘replace the reference oRefFile.ReplaceReference (selectedfile) InventorVb.DocumentUpdate() oOrigRefName = “” Next iLogicVb.UpdateWhenDone = True
Options
- Mark as Read
- Highlight
- Email to a Friend
Status changed to:
Solution Provided
Options
- Mark as Read
- Highlight
- Email to a Friend
Workarounds are not a solution. I just came here looking to post this same idea.
Just like this one: http://forums.autodesk.com/t5/Autodesk-Inventor/De
