Inventor Forum
Replace Component for Derived Parts
7 REPLIES 7
Message 1 of 8
japike
1839 Views, 7 Replies
Add an option in parts created from derived components to replace the derived component.
Peace,
Jeff
Inventor 2022
Labels (1)
7 REPLIES 7
Message 2 of 8
Curtis_Waguespack
in reply to: japike
This is a good suggestion, I do this now with an iLogic rule, but it would be nice to have it built in.
Dim oDoc as Document
oDoc = ThisDoc.Document
Dim oRefFile As FileDescriptor
Dim oOrigRefName As Object
For Each oRefFile In oDoc.file.ReferencedFileDescriptors
'get the full file path to the original internal references
oOrigRefName = oRefFile.FullFileName
	'present a File Selection dialog
	Dim oFileDlg As inventor.FileDialog = Nothing
	InventorVb.Application.CreateFileDialog(oFileDlg)
	oFileDlg.InitialDirectory = oOrigRefName
	oFileDlg.CancelError = True
	On Error Resume Next
	oFileDlg.ShowOpen()
	If Err.Number <> 0 Then
	Return
	ElseIf oFileDlg.FileName <> "" Then
	selectedfile = oFileDlg.FileName
	End if
‘replace the reference
oRefFile.ReplaceReference (selectedfile)
InventorVb.DocumentUpdate()
oOrigRefName = “”
Next
iLogicVb.UpdateWhenDone = True
Message 3 of 8
japike
in reply to: japike
Wow!! That works great. Thanks Curtis.
Peace,
Jeff
Inventor 2022
Message 4 of 8
SteveMDennis
in reply to: japike
Curtis' solution works but we already are considering building it in. [US4564 ] Another workaroudn solution is to rename the file you derived FROM and open the derived part. When you get the resolve file dialog pick the one you want to replace the original source with.
Steve Dennis
Sr. Principal Engineer
Inventor
Autodesk, Inc.
Message 5 of 8
mrattray
in reply to: japike
Workarounds are not a solution. I just came here looking to post this same idea.
Just like this one: http://forums.autodesk.com/t5/Autodesk-Inventor/Derived-Part-Replace-Model-Reference/m-p/3062998#M40...
Mike (not Matt) Rattray
Message 6 of 8
dusan.naus.trz
in reply to: japike
Hi all,
thumbs up = Replace Component for Derived Parts
Please solve, change orientation for derived sketch
derived = I would like to tackle it together.
I use multiple solids. Then I use the derived sketch and I can not change orientation
Please write if you solve it. for steven.dennis
Cheers,
Dusan
Message 7 of 8
dusan.naus.trz
in reply to: japike
Message 8 of 8
Version 2021 is already. In what century do you want to implement the code?-)))
