Reorder of Balloon Stack
There should be an easier method when you have to add a balloon to an existing stack.  When you want them in numerical order, instead of removing the out of order balloons and then adding them back in including the addition,
you should be able to just add the balloon and select where in the stack you want to place it.
12 Comments
I agree, perhaps a simple bubble handle when highlighted, and allow us to drag the individual bubbles around in the stack.
jvj
Cadmanto
That is what I was thinking as well.  Seems simple enough to do.
dan_szymanski
Status changed to: Accepted
Definitely a workflow that could be improved. Accepted idea [US-474]. Thanks!
RobJV
I agree.  Would be nice to have some way of reordering balloons on drawing to make it easier to read and find in the BOM.  IE)  A command to order balloons from left to right on drawing or...
Rob
mcgyvr
The day I have to order balloons like that is the day I get out of engineering/drafting.
Thats just way too OCD in my opinion.
Of course I also stopped using "item #" balloons a while back... I simply put the part number into the balloon instead of an item number. Makes it MUCH easier/quicker for my assembly people to navigate a drawing.
Yes, we use the balloonless balloon with part number on our production drawings and the balloon with Item # on our assemblies for calling out bolts, pins, or anything purchased. But our company isn't obsessed with the order, etc.
karthur1
mcgyvr,
I have been wanting to eliminate the item no. also and just put the part number.  But some of our part no. are like 20+ characters long. They take up so much room on the idw that it really gets messy.
It is much easier not to have to use the item no....I agree with that totally.
dan_szymanski
We are refining procedures around idea status.  Changing this to Future Consideration.
Pate.MacKenna
We use actual part numbers in our balloons, not item numbers, as well.  My fellow engineers have been longing for the ability to reorder a balloon stack by click-and-drag for years.  I would love to see this feature added!
isaac.wegnerHB5JU
Community Visitor
Having the ability to reorder balloons for called out part numbers. Having an option to reorder would be a great help and save a lot of time! Has there been any progress since 2018?
Yijiang.Cai
This has been tracked as [INVGEN-474] for investigation, and will keep you updated on the progress. Many thanks!
Pate.MacKenna
Perhaps the best way to integrate this feature with the existing UI format would be to use the sorting method from the Parts List editor.  It would look something like this:
