My home notes when you've opened/edited the ipt files that are used in the piping environment. This will cover the entire screen in a bunch of identical or nearly so pipes if you've edited a piping run recently. Any file which is edited through frame generator or the piping generator should be excluded from the recent documents list and should only list the assembly it's part of. Otherwise, you get a "most recent documents" list that looks like this:
