Remember MDT AMNOTE?
Wish there was a leader note like Mechanical Desktops AMNOTE that allowed you to predefine the part properties for tags you want to put on the drawing part. Sketch symbols just don't cut it. Hard to set up and text justification doesn't work. The gray area with red text in the below image (for those that never seen MDT) was dynamic linked part info. Worked great and easy to work with and set up.
4 Comments
jletcher
You may want to revisit Symbols I have had great luck with them and text justification there is a lot more control then MDT you just need to learn how to make it work to your favor..
jrhymes
Could you send me an example of a sketched symbol that works like MDT to jason AT deltank.com? I could never find one that worked with the BOM Item Number, Qty and justified when you put it on the left or right side of the arrow. That would be great if there is a way to do it.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
