• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    17 Kudos
    Rearange patterns in assemblies
    Status: Comments Requested
    by maartenverbunt on ‎01-04-2013 07:46 AM
    It would be really great if we could rearange patterns in an assembly. Patterns can not be dragged into a folder. I would really want this so I can easily suppress a folder with, for instance, all fastners.
    Hello, You should be able to drag a Pattern within an Assembly into a folder. Is this specific to a data set? I am able to do this on 2013 and a BETA of 2014. Bryan Kelley Sr. Software QA Engineer DLS – Mechanical Design
    Comments
    by Contributor timdown73 on ‎01-04-2013 12:54 PM
    YES!
    by Employee bryan.kelley on ‎01-29-2013 01:22 PM
    Status changed to: Comments Requested
    by Active Contributor cadull_rb on ‎01-29-2013 01:58 PM
    I think the issue is the limitied ability to reorder items in the tree, which can be required to reach the intended folder. For example:
    1. Place a part in an assembly and create a pattern.
    2. Place three more parts in the assembly and place the last two in a folder.
    3. Now we have a pattern, a part and a folder containing two parts in the tree.
    4. The pattern is not able to be relocated below any of the following parts and so cannot be included in the folder.
    5. We can however, drag the folder next to the pattern and then include the pattern in the folder (at the start if the folder is below, or at the end if the folder is above the pattern).
    cadull
    by *Expert Elite* on ‎03-28-2013 07:25 AM
    FYI, Cadull's suggestion only works if there isn't a pattern already in the folder. If the folder contains a pattern it cannot be reordered either. Hence, if you have a folder with a pattern in it, seperated by a part (or third pattern) from another pattern you cannot place that pattern into the folder.
    by *Expert Elite* on ‎04-05-2013 08:27 AM
    Also tag into this idea fixing the component pattern browser icons. Currently a suppressed pattern icon is identical to a not visible pattern icon. They should match the part/sub assembly icon theme.
    Example:
    The patterns in the red box are not visible, the pattern in the blue box is suppressed. Note that these patterns would be grouped together if the main idea of this thread was implemented...
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea.
