Queue renderings
Queue renderings
I don't think there's currently a way to do this.
I thought there could be a button added to the rendering window which allows you to queue up renderings.
You could set up the camera angles and lighting as normal.
Click render.
Select the camera, lighting and environment as usual, but then click queue instead of render.
THis would add it to a queue. You could then select different angles and lighting and click queue again.
Once you have a few renderings set up, you can click render, go home and then next day you have several renders from different angles complete.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
