Project work plane in a drawing view sketch
In a drawing view you can include a workplane from the model. But when a sketch is made onto that drawing view all model edges can be projected but the included work plane cannot.
I would like to see the possibility of projecting work planes in a drawing view sketch.
Related post: http://forums.autodesk.com/t5/Autodesk-Inventor/Constrain-section-view-to-work-plane/td-p/4317692
4 Comments
this would be really helpful in drawing dimensioning.
LukeDavenport
This is vital for some construction companies (curtain walling, roofing, envelope design) who may have workplanes that represent gridlines in their assembly, that they need to refer to for section positions in detail drawing views. Please consider this Autodesk as it should be a simple but valuable inclusion into the software.
dan_szymanski
Status changed to: Duplicate
This idea is a duplicate of http://forums.autodesk.com/t5/ideas/v2/ideapage/bl​og-id/v1232/article-id/1541 which is Accepted [US21110]. Please be sure to cast a kudo to the other Idea if you haven't yet already to avoid splitting the kudos. Thanks!
dan_szymanski
This Duplicate idea has been implemented within Autodesk Inventor 2016. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it.
