Hallo togehter,
I think it would be a nice feature if there is the possibility to define a pattern of elements or bodys in part or parts in assembly, by selecting another pattern in the assembly for example. Or by selecting a sketch.
So it would be possible to define patterns with unsimilar gaps between to positions. For example you have a straight pipe and you need 3 inlet positions on it. The first position at 0mm, the second at 200mm and the third at 600mm. All inlets are similar. This could be possible with a sketched path with positioning points i think.
Best regards,
David
