Pattern connected to other patterns or sketches
Hallo togehter,
I think it would be a nice feature if there is the possibility to define a pattern of elements or bodys in part or parts in assembly, by selecting another pattern in the assembly for example. Or by selecting a sketch.
So it would be possible to define patterns with unsimilar gaps between to positions. For example you have a straight pipe and you need 3 inlet positions on it. The first position at 0mm, the second at 200mm and the third at 600mm. All inlets are similar. This could be possible with a sketched path with positioning points i think.
Best regards,
David
3 Comments
Agreed.  For instance, In Creo you can pattern holes to a sketch of randomly placed points.  This is extremely helpful.  In inventor you seem to be limited only to rectangular or circular patterns of features.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
