Partslist Header Text Wrapping And Partslist Footer
It would be great if it were possible to wrap the text of the column headers on partslist or any other table for that matter.
It would also be very advantageous to be able to add a footer to partslists which at present we can only do by the use of a sketched symbol on the drawing. When we produce a material cut list we always include a footer givin the fabricator a little room to manouvre with regards to material specs etc and this would be great to have built into the partslist and configured into the styles.
If you would find this sdort of thing useful then give it the thumbs up!
4 Comments
dan_szymanski
The Master Idea for the ability to wrap a parts list (or other tables) can be located here:
http://forums.autodesk.com/t5/ideas/v2/ideapage/blog-id/v1232/article-id/2496
Lets use that Idea to capture that request and keep this idea seperate for Parts Lists Footers.
Thanks!
Dan
carolsuehogan
Observer
Yes, drafters creating tables for parts, specs, materials, etc., we want the ability to text-wrap the column headers. This was even a discussion in my CAD college classes, how Inventor does not listen to what we "need". We spent a lot of time learning "work-arounds".
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
