Partlist in idw about Component only
In Some Case, Part or assembly quantity is required in drawing about top assembly
Top Assembly drawing can place a partlist about all component
In component drawing can place only partlist about itself and quantity is 1
if i want to insert using component quantity about top assembly , i should place a top assembly partlist and change a visibility of not using component.
So i want place a partlist with quantity that is using a top level assembly
4 Comments
jhunt107
I see this question A LOT. The part files have NO relationship to know which of the parent assemblies they are used in.
How would you like to define which assembly the QTY is pulled from?
- Josh
sbkim
I think that the best way to fine relationship between part and assembly is relationship part and assembly
But there is no option for checking part used without Vault(where used)
So currently Partlist for part with qty about assembly is created with full assembly partlist and suppressed all part and component except part
I suggest a function that designate a assembly manually in part or component partlist there are used
jletcher
OMG this also can be done with ilogic look it up in the post I have this function and it is great.
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
