Hi Guys,
Please find listed below my ideas (and some from Brian Cranston - thanks Brian) re possible improvements to Inventor Sheet Metal. Please feel free to add any that we have not already thought of:
1) Fully controllable gussets, including draft, etc. User drawn profiles allowing the construction of a gusset across two bends or across a non-linear bend)
2) Easy way to make press tools and add them to a library.
3) Zero gap hems.
4) Dimple tool.
5) Bead tool.
6) Louvre tool.
7) Obround punch tool should be unlimited in sizing (currently limited to 4 pre-set imperial choices only).
😎 Better corner treatments.
9) Drawn cut-outs used to form open depressions with folded down/up edges (see image 1).
10) Conversion from outsourced CAD files straight into sheet metal with feature recognition.
11) Sheet metal create “Face” to show editable "sheet metal defaults" in the pop up menu.
12) Corner seam Face/Edge distance to accept “0” gap.
13) Punch tools need to have a preview of effect to changes of size geometry prior to application.
14) Joggle tool.
15) When using the flange tool to create adjacent return flanges the software automatically mitres the overlapping corners. This is also a requirement for some contoured flanges, but there is no facility to do this. Neither is there a facility for selecting multiple edges (chaining) when creating a contour flange (this is where automated mitres would also come in to play).
16) Emboss tool to displace metal if required (see image 2).
17) Allow punching across bends, the addition of beads and other punch tool features directly on the flat pattern.
18) Flat pattern suppression (for parts with high bend counts, without destroying drawing link).
19) All modification of bend allowance as part of the bend data. Sometimes bends stretch in a fashion that Inventor won’t predict. I’d like a box to add/subtract a value from the bend allowance.
20) Piercing & stretching tool (e.g. countersunk holes). This feature might be treated separately or grouped within item 9. It could also be used to create extruded threaded holes, another highly desirable addition (see image 3).
21) Content Centre to have full catalogues of sheet metal fasteners from “PEM,” “DZUS” and “TR” – and yes, I know that both PEM and TR have some identical parts.
Please Note: The ideas for items 18 and 19 should be credited to Mr. Brian Cranston.
Regards all,
Dave
MDLtd
www.mdltd.org
