New Stress Analysis Contact Type - Bonded Within Weldment / Subassembly Only
I do a lot of FEA with multiple weldments.  Usually I'll set the default contact type to separation, generate my automatic contacts, then I'll select the welds for each of the weldments and set those to bonded.  The problem comes up when weldment A is resting on weldment B, and there's a weld in one part that's touching the other part.  When I set the welds to bonded, I then have to go through all the other contacts to find all of those unwanted bonds and change them back to separation.
It would be really great if there was another contact type, or even just a checkbox or something, so that when you set the contacts to be bonded, it would only bond within the subassembly where the welds are located.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
