New Part "Part Number" Problem
When creating a new part that is similar to another part I will sometimes do a “saveas” of the original part.  Apparently Inventor doesn’t update the “Part Number” section in the iproperties with the new File Name. This  is a problem when using the Bill of Materials in a detailed drawing because Inventor uses the “Part Number” in the “Description” column of the BOM, not the File Name.  It also groups parts based on their “Description” and not their File Name.  That means that 2 parts that are physically different and their File Names are different are counted as multiples of the same Part in the BOM.
3 Comments
MattH_Work
We should have options as to what property we merge on. I like to merge by Part Number, you want to merge by file name and someone else wants to merge by Description.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
