10 Kudos
Match flange angle to adjasent edge
Status: New Idea
by adurr on ‎10-17-2013 12:02 PM
In sheet metal I would like to be able to match the angle of a flange to the edge of a part.
Comments
by *Pro on ‎10-18-2013 04:05 AM
This can be done already..
 In sketch with cutout turn viz of sketch on and select the dimension....
by adurr on ‎10-18-2013 09:47 AM
The problem is that I get the lengths of the sides from the customer, and do not dimention the angle.
by *Pro on ‎10-18-2013 10:55 AM
Dimension the dam thing. OMG how lazy can you be...................
Do you want it so Inventor can do your job too...........
 And if you don't want to dimension it then use the measure in the drop down for the angle....
But if it was me I would dimension it so if the angle changes so does the bend...
Unbelievable......
You are not logged in.
IdeaStation Guidelines
Review guidelines and best practices
before posting a new idea.
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
