Match flange angle to adjasent edge
In sheet metal I would like to be able to match the angle of a flange to the edge of a part.
5 Comments
jletcher
This can be done already..
 In sketch with cutout turn viz of sketch on and select the dimension....
The problem is that I get the lengths of the sides from the customer, and do not dimention the angle.
jletcher
Dimension the dam thing. OMG how lazy can you be...................
Do you want it so Inventor can do your job too...........
 And if you don't want to dimension it then use the measure in the drop down for the angle....
But if it was me I would dimension it so if the angle changes so does the bend...
Unbelievable......
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
