Make the view SCALE property available in the Title Block
The default title block (and many custom title blocks) contain a SCALE entry. There is currently no way to associate the View Label Properties<SCALE> to the title block as an associative Property. The View Label Properties is not available when you are customizing the title block.
4 Comments
I agree this wuold be useful, as it is something you can do with Part Number (although it associates with the first view you create, so you need to plan your layout).
michael_marx
ilogic can do this for you! Smiley Wink
dan_szymanski
Status changed to: Duplicate
This is a duplicate entry. Please refrain from casting kudos to this idea as to avoid splitting votes. Please use this Idea when applying Kudos: http://forums.autodesk.com/t5/ideas/v2/ideapage/blog-id/v1232/article-id/457 Thanks! -Dan
dan_szymanski
This Duplicate idea has been implemented within Autodesk Inventor 2016. Special thanks to the author of this Idea and likewise to everyone who cast your Kudo for it.
