Look-At section view surface in a model
After creating a section in a model, I would like to pick  the surface that was cut thru and use the Look At command to view the section straight on.
4 Comments
cbenner
You could just click on the view cube....
crmayo
Sometimes - In the section shown above, the assembly is rotated 5 degrees out of position from the world.  This is another reason Inventor should let your rotate the model in preset increments.  Personally I would use shift+arrows   http://forums.autodesk.com/t5/Inventor-IdeaStation/3D-Orbit-specify-a-degree/idi-p/4374018
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
