It would be good to allow to use the same node name in the Features tree view as a node in the Solid Bodies tree view. Currently, I have to enter two different names (one for the Features tree view and a sligthly different one for the Solid Bodies tree view). For example, if I create an extrusion called
"Back", I can't then rename the newly generated Solid Body node "Solid1" to "Back" as well. So I usually call the feature "Back Profile" and the Solid Body "Back". But it would be good to be able to name them indentically for easy reference.
A step further would be to automatically link the names, especially for solid generating features (Extrude, Revolve, Loft or Sweep). So when the feature node name is renamed, the associated soild body could be renamed too, or the featured could be called "<Solid body name> + Extrusion".
