Either fix, explain what to do, or make option. The sketch command in Inventor for Line, should only create lines. When i move around fast, and pick points, between click and drop, I get many many arcs. Arcs are not lines. They are not even the same number of click points. This must be fixed, and I don't even know how a programmer would have thought the line command should create arcs. This issue has been around since 2010 (or earlier) all the way through 2015 (which just came out yesterday) so what gives?
I want to be able to click fast and get nothing but lines as expected. I thought that was fixed in 2015, when they said that mouse down was the official point event not mouse up, but apparently not. It's time speed enhancements at the fundamental level are completely addressed.
jvj
