Last used tab on the iproperties dialogbox
If i leave the iproperties dialog box, it would be nice when entering again the dialog box, to show me the last accessed tab, because most of the time, that's the tab i need to change again.
Also other dialogboxes could benefit from this feature (pe.: app options)
2 Comments
mikeh4
I would highly recommend Sean Dotson and Neil Munro's iProperty Wizard.  Greatly simplifies modifying iproperties and also helps standardize by giving the ability to generate pull down lists for select properties limiting the users data that can be populated to the iproperty.  You can also require fields be entered or no properties populate at all forcing users to fill them out.
Rich-T
I heartily endorse the idea of having the iProperites dialog box open on the last used tab.
It would be a big time saver.
A solution that does not require the use of ilogic/vba /macro/app is a good solution.
This should have been done years ago.
