- Mark as Read
- Email to a Friend
- Printer Friendly Page
- Mark as Read
- Highlight
- Email to a Friend
Hi arjendenobel3640 ,
If you go to the Tools tab > Document Settings button > Drawing tab, you should find a setting called Dimension Updates.
You can set this setting to Sheet Position and Maintain Centered.
This settting retains centered dimension placement while all other dimensions maintain their positions on the sheet.
Is this what you're after?
Also, you can adjust the default placement behavior by going to the Tools tab > Application Options button > Drawing tab, and setting the Center dimension text on creation option.
See this link for a bit more on using that settting (the last paragraph sepecifically):
http://inventortrenches.blogspot.com/2011/08/drawi
I hope this helps.
Curtis
- Mark as Read
- Highlight
- Email to a Friend
- Mark as Read
- Highlight
- Email to a Friend
Thanks Curtis, that did the trick.
