Show only
Search instead for
Please repair the material behavior during the exchange between Inventor and Revit !
This (wrong) behavior take place since Solution 2013 (for both Programs Revit and Inventor). I have addressed this in several Autodesk forums (Inventor and Revit Beta Beta). For years nothing happened😞
For Shop fitting and interior design we make the construction design with Inventor and the further planning with Revit. For this Workflow it is necessary to import and export files from and to Revit and Inventor.
Our most important Problems in this Exchange are: Materials Corrupt Surfaces
Attached you will find a description of some “Breadboard” of this Problems as PDF. Please solve this problems as soon as possible !
Or... put a STEP translator in Revit. There's already a STEP translator add-in you can buy, but AnyCAD would seem the logical choice for handling native RVT files. Great suggestion.
I'd like to see associative links which work both ways, that is not only associative linking of Revit models which have been passed to Inventor, but also Inventor models which have been passed to Revit. Since Inventor models imported as ADSKs into Revit can become unmanageable because of their complexity, it would be nice if the linked files could be light weighted without first simplifying the geometry in Inventor as is currently the approach. It would also be nice to have active links between Inventor drawings placed into Revit drafting views.
A round trip work flow between Inventor and Revit would be great, but in the mean time, it would be nice if Inventor assemblies could be exported as ADSK "assembly'. For example, an Inventor assembly would export to an ADSK which when inserted into Revit would become a Revit assembly where each Inventor part in the assembly would translate to a Revit family within the assembly allowing tagging etc... in Revit.
@fsanchou, could you provide an explanation of what this suggestion is requesting? I understand it has something to do with exporting from Inventor to Revit, but I'm not entirely clear on what the diagram is trying to communicate or what specifically you want this Export functionality to be capable of. Thanks!
With Inventor we are able to create parametric design with many method : iPart, iLogic ...
Today simplification is not very smart, very manual, difficult to reuse, ...
Today export RFA don't use Inventor parameter, RFA object is a "dead object" without link : Any modification in Inventor oblige to redo all step any time.
