Inventor Pipe Auto-Routing; option to constrain to natural X,Y,Z axes
An option to have piping AutoRoutes be automatically constrained to the X,Y,&Z axes would be a huge help. For most industrial piping systems I'd say 99 times out of a hundred the designer wants pipe aligned with the natural axes.  For the times where the route angles don't matter just unselect the option to see the non-plumb routes Inventor offers.
5 Comments
cbenner
I like this, but I'd rather have each new run, as well as the top level Tube & Pipe runs assembly automatically constrain origin plane to origin plane.  Tube & Pipe assy constrained to parent assembly, and each successive run constrained to the Tube & Pipe assy.  That way NOTHING moves by accident, causing youe entire assembly to get.... ugly.
I just worked on some tube and pipe and the only autoroutes it would give me were diagonal. I had to fight it by manually adding elbows where I wanted them in the assembly environment and constraining them in the XYZ axes. Took a lot longer than it should have.
lesmfunk
And, for bent tube routing, the xyz bend machine output file starts somewhere in outer space. It should start at X0, Y0, Z0.
Great Idea!
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
